P1337 code help!
Old Aug 29, 2013 | 07:45 PM
BradEK9's Avatar
Icon2 P1337 code help!
Alright so I have an lsv swap in my 98 ek coupe, I'm trying to pass inspection, I have the stock harness in obd2a, I put my stock ecu in p2p to see what codes were coming up it is p1337 what can I do to get rid of it or bypass it cause the b18b I believe doesn't have a crank sensor any help thanks
Old Aug 30, 2013 | 01:44 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: P1337 code help!
http://technet.ff-squad.com/ckftrick.htm
Old Aug 30, 2013 | 03:50 PM
BradEK9's Avatar
Originally Posted by HondaPartsHero
I did that and then I got a different code I think it was the cyp or another crank code, any other suggestions ? Please anyone I need it inspected by Monday I been doing this for 2 weeks now
Old Aug 31, 2013 | 03:13 AM
Technical Hero
Did you try the fixes in the red letters for when the other code pops up
Old May 14, 2014 | 05:50 PM
cheekno's Avatar
all obd2 motor have a crank sensor. if the vehicle is an obd2 with an obd2 ecu, it'll throw either p1337 which means something wrong with the wiring to the sensor. or p1336 meaning no sensor detected. if u r running an obd1 motor in an obd2 vehicle with an obd1 ecu it'll bypass the crank sensor since obd1 don't use crank sensor. this will also bypass an obd2 motor also if ur using an obd1 ecu(note to run an obd1 ecu to a obd2 harness a jumper is require).
sikcrx80
May 1, 2023 05:16 PM
joshd_bh
Sep 5, 2012 08:14 PM
slo97coupe
15
Mar 19, 2006 07:59 PM
socki18
Feb 16, 2005 12:47 AM
Flamenco-T
Sep 8, 2002 12:05 PM
