Gsr swap into an 95 eg
I'm in the process of swapping a gsr into my 95 stock eg. I have innovative motor mounts to install which include the driver side, rear mount, and trans mount. Do I need the driver side mount that is connected to the AC compressor and block. The bushing is already shot. Also my motor mount kit did not come with any hardware. Where can I get new hardware? Thanks
Location: Pensacola, FL and every Court House in Louisiana
Re: Gsr swap into an 95 eg
That is a torque mount. There is also another one on the front of the transmission. Some will say yes you have to have them even with aftermarket mounts. I ran without both for almost a year in my gsr swapped 94 hatch and hasport mounts before installing the trans side only. Never had any problems and only reason i did install was due to wheel hop at the drag strip. I think the transmission side is more important. I have not used the ac torque mount ever
blueskiesfade609
10-27-2005 02:59 PM
RICE POLICE SIP
01-07-2005 03:09 PM
handa
05-22-2004 07:50 PM
