Need help please
Old Jul 21, 2013 | 11:46 AM
ChrisHdz94's Avatar
Default Need help please
Hi i have a 93 cx civic hb and i want to do a swap. I have a d15b8( slow as hell) and want to put a d16y8 or a d16z6 if ima do the whole engine and tranny swap, what do i need entirely to have to have for the car to be runing and performing like its supposed to? All the help i can get is aprecciated
Old Jul 21, 2013 | 01:04 PM
tampered's Avatar
Default Re: Need help please
http://zealautowerks.com/dseries.html
Old Jul 22, 2013 | 09:33 PM
99vtec_sauce's Avatar
Well actually it should be fairly easy for you. Your looking to stay single cam. Only difference is you want to go vtec.
Heres a list of items you should be able to reuse if you cant find or want to go new.
axles
radiator
shift linkage
mounts
exhaust manifold, but id really recommend z6 or y8. I think the b8 would be restrictive for the power your looking for.
Now easiest route for you would be a z6 because it is obd1. If you could come across one complete that would be good for you but if not its still do-able. Putting the motor in would be the exact as you pulled it just in reverse. All mounts are in the same spots. Id recommend a z6 engine harness for plug and play operation. If not you would have to wire in vtec pressure switch and solenoid to the ecu. Not difficult but why hack stuff if you dont need to.
So things you would need.
z6 motor
z6 trans
z6 harness
z6 distributor
z6 alt.
obd1 p28 ecu
Hope this helps... Like I said should be pretty straight forward. Good luck.
Old Jul 30, 2013 | 07:01 PM
ChrisHdz94's Avatar
Thanks for the info, really helped
Old Jul 31, 2013 | 08:05 AM
HondaPartsHero's Avatar
Technical Hero
axles
radiator
shift linkage
mounts
z6 motor
z6 trans
z6 harness
z6 distributor
z6 alt.
obd1 p28 ecu
This plus even if you use the z6 engine harness you'll still need too manually wire vtec from the shock tower to the ecu. Or you can also resuse the cx harness and wire vtec and 02 manually.
cruspeed^2
Jul 10, 2013 07:52 PM
93hatchdude
31
Feb 28, 2007 12:26 PM
PoWeRBaN_PaNdA
Mar 29, 2004 06:00 PM
89dohcEF
Oct 28, 2003 07:58 PM
redrex
Aug 28, 2003 08:38 PM
