B20 swap questions
B20 swap questions
I am swapping a b20 in my 91 wagon. The questions I have are:
1. Which rear engine bracker do I exactly need. I am using Hasport mounts for ef chassis with cable tranny. Will the bracket that I took of the b16a fit?
It mounts of to the rear mount on the subframe, but I do not see where it would bolt onto the b20 though.
Or is the #11 bracket in the link the only one that will work. Looks different from the picture. http://www.acuraoemparts.com/delray/...All&vinsrch=no
2. The side bracket by the timing belt cover. When I put my hasport mount on this is is no vertical to the engine. Which bracket will I need for this mount to line up properly?
2. Can I just use the Intake manifold off the b20b. It is not the giraffe looking one. As well as the throttle body and cable?
Re: B20 swap questions
What about the intake manifold is the b20b manifold fine to use if it is the low cut one. Or how much power difference is there if I also put on a DA manifold.
What headers will bolt up to a b20b Only the DA headers, and downpipe?
Also does it matter which engine the da has. Because they came with a b16a/b17a/b18a. http://en.wikipedia.org/wiki/Honda_I...DA9.2C_DB1-DB2. I would assume I would have to find a DA with a b18a. Because the B18 and B20 are pretty much the same engine.
