b18b1 help
Old Aug 23, 2013 | 09:16 PM
elnene_14's Avatar
Default b18b1 help
hi im trying to get help on my swap... I have a 92 hatchback with ls motor that im having problems it runs fine until 4500rpm and if I hit the throttle all the way ill bogg like it doesn't have gas .. I cleaned the injectors change tps have installed 3 different throttle bodies change full pump filter timing I have done so many thing I dnt know whats the problem I hit the throttle all way and spry carb cleaner and revs fine I think its short on gas but why?
help pls thanks
Old Aug 24, 2013 | 05:21 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: b18b1 help
A few questions:
Is the check engine light on?
When you replaced the TPS did you calibrate the voltage?
What ECU are you using?
You checked ignition and cam timing?
Old Aug 24, 2013 | 05:21 PM
elnene_14's Avatar
No check engine.. dint replace tps just hole throttle body .. I have tried pr3 p06 p05 and the stock p75... timings its good replaced spark plug cables and cap..
Old Aug 24, 2013 | 05:25 PM
elnene_14's Avatar
If I put my hand half way throttle it revs fine so that why I say it short on gas or 2much air
Old Aug 24, 2013 | 06:13 PM
Technical Hero
Check your TPS voltage and check fuel pressure
Old Aug 25, 2013 | 06:44 AM
elnene_14's Avatar
What voltage its supposed to have and preasure
Old Aug 25, 2013 | 06:46 AM
elnene_14's Avatar
And I've change fuel pump already.. ?
Old Aug 25, 2013 | 08:51 AM
efinimazda's Avatar
crank sensor?
Old Aug 25, 2013 | 10:55 AM
elnene_14's Avatar
thanks I found out looking at the fuel rail I put 2 washers at the end on one side and the line wasent on the correct spot that's why it wasent getting gas..
thaks 4 the help
si del sol 94
18
Sep 16, 2009 07:39 PM
.Jay
May 6, 2006 12:57 PM
98TypeSH
Apr 26, 2004 10:25 AM
kefka
Feb 13, 2002 11:36 PM
