What do I need for AC in my Type R Del Sol?
Alright so I swapped a JDM 98-01 Type R in my 94 Del Sol S. Originally I was gonna leave AC out of the car to put a larger radiator in it but now that summer is here I realize I need the AC more than I thought. So my question is what components do I need to get running AC and could anyone lead me somewhere with instructions on how to install it?
I believe the engine came with the compressor(if that's what the AC component is called actually attached to the engine).
So what else do I need? What model and year should the Condensor, wiring, bracket, and whatever else I would need to come out of. I don't know all components of an AC system so please let me know anything I missed. When I bought the del sol it didn't have AC in it so I haven't had AC for the life of the car, so I have no D series components for it.
Thanks!!
Thanks!!
Re: What do I need for AC in my Type R Del Sol?
you can use all the stock stuff from a Del Sol . You just have to buy a Del Sol VTEC A/C compressor bracket. Then it all bolts in. Hard to say what you need cause you don't know what you have.
If you want to use the Type R compressor you will need A/C lines to match it.
Your Del Sol was R12 and any new parts you get will be R134. It would be best to buy a complete used R134 system from a del sol, the VTEC bracket, new o rings, new expansion valve, and new dryer. Then have a pro install it. AC components are very finicy and if you dont know what you are doing installing them and properly oiling and charging them they will not work correctly.
JinDIESEL
09-03-2004 05:54 AM
