90 crx si swap b18a1
Hey there I just got done swapping a 90 ls into my 90 crx si and now it go to gear put wont lock? Does this mean I need a new clutch? When I put it in 1st gear I can still push the car. I need help because this is my dd.
Re: 90 crx si swap b18a1
If u mean it won't go into gear? Maybe your shift linkage might be bent. Have u tried putting it in first when it's off and moving it that way?
Even a clutch worn past the service limit will grab a little, enough to hear grinding sounds if you push it while in 1st gear. Check to see the shifter IS putting it into gear, and as mentioned, make sure both axles are in 100%. If one isn't in all the way and you have a non-LSD trans, the diff will spin and not get "locked" by the motor&clutch.
oneeezy
08-22-2010 06:33 PM
Pnoyej6
14
05-05-2006 09:29 PM
b20vtecv8killer
08-02-2004 08:23 AM
