Jdm H22a intake manny
Old 07-24-2013, 09:07 PM
H22AEX's Avatar
Default Jdm H22a intake manny
so i went recently to get my civic barred , and i got some feed back from the reff i gues i have to get a AIR BOOST VALVE ? and a IAB Solinoid . i guess the jdm motors and mannys never came with a airboost valve they have a block off plate. so does anybody know if the f22's have these parts and if so can i use them ? cause these h22's are rare to find in the junkyards and retail stores dont carry them.
Old 07-24-2013, 09:25 PM
Emeraldbomber's Avatar
Default Re: Jdm H22a intake manny
What about the h23?
Old 07-26-2013, 08:27 AM
ESP.net's Avatar
The boost valve should be on the end of the plenum. You will need the black box should be the same as the Accords and the solenoid you will need to run all vacuum lines properly and wire it up. You will also need to have all EGR parts to get that to work properly
Old 07-29-2013, 11:30 AM
H22AEX's Avatar
yeah i got all the EGR equipment and the only thing i need to find out is if the Intake air bypass control solenoid valve will work from a f22 for a H22?
holmesnmanny
12-14-2010 03:21 PM
1991civicd16z6
Northern California (Sales)
09-17-2008 04:09 PM
k_spek
03-06-2007 12:19 AM
Quick Reply: Jdm H22a intake manny
