cv joint on eg hatch
Old Jul 2, 2013 | 10:31 AM
kiko_eg-hatch's Avatar
Default cv joint on eg hatch
Can sum1 help me out n tell wich cv joint I. Should buy for my eg hatchback. It has b18c swap. I bought sum 97 integra shatf they look shorted then the 1s I took off not. Sure if Igot the wrongs or If the store gave the wrongs
Old Jul 2, 2013 | 10:33 AM
skill178's Avatar
Default Re: cv joint on eg hatch
Do you have the half shaft?
From my experience you always match the axels to the tranny
Old Jul 2, 2013 | 01:11 PM
sidewayz6.6's Avatar
This. Also, see if there is a difference in axles between the integra ls and the integra gsr.
Old Jul 2, 2013 | 08:18 PM
Old Jul 2, 2013 | 08:54 PM
The half shaft is on the driver's side rite cause im swaping out the passenger side shaft
Old Jul 2, 2013 | 08:58 PM
Im finna see 2mmor wen I go 2 the auto parts cuz I told them it was for the gsr n not ls
Old Jul 2, 2013 | 09:02 PM
slowDB7's Avatar
you can check online if they are the same check autozone and see if part numbers are the same...or check hondapartsunlimited.com to see if they are the same
Old Jul 3, 2013 | 05:12 AM
kyden's Avatar
90-01 integra passenger side axles are the same.
fin781
Dec 12, 2009 05:29 AM
OverBoostDemon
Nov 3, 2009 09:58 AM
DB1_559
Aug 6, 2005 04:27 AM
hondaguyexsi
Jun 23, 2005 08:01 AM
brandond
Jan 17, 2005 09:49 AM
