F20B EG swap
Old Aug 20, 2013 | 07:31 PM
Bmocc's Avatar
Icon2 F20B EG swap
Hi, I want to put this F20B http://www.jdmenginescorp.com/engine...5spd-lsd-trans into my '93 Hatchback. I was hoping if someone would be so kind enough to tell me everything I need to complete the swap.
Old Sep 26, 2013 | 11:09 AM
fseries_dc2's Avatar
Default Re: F20B EG swap
what mounts are u planning to use
Old Sep 30, 2013 | 03:12 PM
2.3h2b's Avatar
you will need the prelude half shaft,hasport axles for h swap,motor mounts for hswap,doner ECU or a chiped ecu with a h series base map clutch/flywheel for h/f series extend the pig tails on the harness other minor things the transmission that comes with the f20b"t2t4" is recommend.If you are going f2b f20b with a b series transmission I can help you out with parts list to.
Old Nov 14, 2013 | 12:19 PM
Bmocc's Avatar
My bad, too long opf a response but here's the swap I'm getting now: http://www.jshmotors.com/jdm-f20b-mo...mplete_p31.php
The Axles I'm getting: http://www.driveshaftshop.com/import...mount-kit-only
The engine mounts: http://hasport.com/store/index.php/m...s-eg/egh3.html
and I'm getting an H22 Skunk2 intake manifold. From that swap list, is there anything else I need?
Old Nov 18, 2013 | 08:11 AM
2.3h2b's Avatar
I forgot about the shift linkage from the prelude if you are going full H/F or any B series for h/f2b its a great swap check out my YouTube channel
f2beasteg I have plenty of videos of my f20b
Old Dec 2, 2013 | 02:55 PM
Bmocc's Avatar
I'm going full F20B with the T2T4 tranny. The swap I linked does include the Prelude's half shaft thankfully. I'm fully building the head with all H22 parts because I've been informed they are the same head. I'm also using an H22a1 engine harness and the EG's stock interior harness so everything is OBD1 and I won't have any problems there. I know I have to cut my shell's shift-box hole to make it square for the F20B's. Have I covered it all?
Old Feb 13, 2014 | 07:24 PM
daniel_ej6's Avatar
can you help with parts list for an ek coupe "DX" f2b swap ?
poseghatch
Apr 5, 2013 06:32 PM
jaron711
Oct 5, 2009 02:34 PM
vtec94civic
May 4, 2007 10:26 AM
hondatuner020
12
Apr 11, 2007 07:11 AM
