wiring 5g civic ecu to 4g car
i have the helms manual for my 4g civic, but i need just the wiring diagram for the ecu > car interface for a 5g civic (sohc vtec swap). can anyone help me out?
Re: wiring 5g civic ecu to 4g car (serious)
You will need pr3 or pwo auto ecu or rpm activator but try 6g motor cause you cant use 5g distributor with out much work. 6g's head accepts 4g distributor and has knock. Rev on auto pr3 and pwo is 7200 and a better map.
here, follow these instructions and you'll convert your obd0 car to obd1
http://www.geocities.com/kurtsi_on/page7.html
good luck
Lester
good luck
Lester
Re: wiring 5g civic ecu to 4g car (lelopez)
i'm actually going to be using the d16z6 ecu, not the 90 ecu, and i'm trying to find out how to connect the wires between the z6 ecu and the car itself.
Pure stock S2K
01-17-2015 07:42 PM
koler
08-25-2006 02:08 AM
