Vtec spool solenoid valve circiut?!? what is this?
Old 05-20-2002, 02:09 AM
infamousALLMTR's Avatar
Default Vtec spool solenoid valve circiut?!? what is this?
this is the code I am pulling right now on my car... (just put in my engine) and the vtec is not kicking over code 21 which is what the title of this post is. I dont know why vtec is not kicking in.
Old 05-20-2002, 02:26 AM
Default Re: Vtec spool solenoid valve circiut?!? what is this? (infamousRRH)
need to know its 3 in the morning...
Old 05-20-2002, 07:54 AM
Kataku2K3's Avatar
Check your VTEC solenoid wiring.. If the clip is unplugged you should be getting this code. If that's not the case then trace the wiring from the VTEC solenoid to the ECU and check for continuity.. It's most likely a wiring problem.
Old 05-20-2002, 12:29 PM
New User
jetli6969's Avatar
Default Re: Vtec spool solenoid valve circiut?!? what is this? (JDMspecEG6)
i would like to know also i get this code at times. it comes and goes.... and what if its not the wiring..
Old 05-20-2002, 01:19 PM
Jackson's Avatar
Default Re: Vtec spool solenoid valve circiut?!? what is this? (jetli6969)
Then its a faultly/defected solenoid and/or you are low on oil and do not have enough oil pressure to back up the solenoid to engage in vtec.
Old 05-20-2002, 02:53 PM
Default Re: Vtec spool solenoid valve circiut?!? what is this? (Jackson)
we got it fixed and vtec is very nice... someone showed him a diagram and it was actually backwards, turned it around and VTEC.
Old 05-20-2002, 04:10 PM
AzN_Flava's Avatar
Hey man KEEP all those diagrams and scan them for me! hehe I would GREATLY appreciate it... or better yet wanna write a step by step on the wiring process? haha
Anyways i'm glad to hear your car is running.. now video tape it already!!
m_wnzl
Honda CR-V & Element
02-10-2016 01:30 AM
kornerk12
04-19-2007 08:41 PM
over_
12-02-2006 03:55 PM
dturbo
08-04-2005 06:07 PM
r7
11
05-29-2005 12:55 PM
Quick Reply: Vtec spool solenoid valve circiut?!? what is this?
