Any teg owners with an h22 swap?
i'm looking into doing this swap this summer but i need to find out some specifics first. wat parts will i need to complete the swap like axles, shift linkage, mounts crap like that. wil my oem radiator fit? considering it will probly be a obd1 motor with lsd tranny. should i change out my fuel pump since my car is an ls. any help is appreciated
Re: Any teg owners with an h22 swap? (TKBLAZER)
do a search for Hasport (they make mounts for this swap). You're going to have to install a prelude cable shifter. Power steering and A.C. are out of the question (unless you can make different mounting locations for the condenser and p.s. pump). i don't know which axles you'll need.
you should turbo it when you're done. Plenty of room for a fat downpipe
