which mounts??
Old May 17, 2002 | 12:58 PM
sydag5's Avatar
Default which mounts??
Which mounts do I need for my LS swap into my 98 civic? Also if I use my DX wiring harness will I have to repin anything?
Syd
Old May 17, 2002 | 08:04 PM
dumbmadtech's Avatar
Default Re: which mounts?? (sydag5)
Rear mount SI,Rear bracket Si, upper tranny yours ,lower tranny any Bseries. AC compressor mount P54 del sol dohc or B20 if your keeping AC, Timing belt mount to the block you will use SI or DA integ or 1 gen b16 or P30 2nd gen B16 or even B20. As far as the wires Idle air will need mods and so will crank angle wires from 3 to 2 wires. I hope its 96 or newer or get ready to shell out cheese. You need oilpump,crankangle sensor, A new sprocket for the crank and a new lower timing belt cover. ECU wise it may be cheaper to scrap all OBD2 stuff and buy 92-95 Teg computer and get harness converter.
dntbh8n
Apr 7, 2006 06:47 AM
superpirate25
Oct 9, 2004 01:53 PM
boomslang
Oct 27, 2003 04:49 PM
GReddy SI
Jan 3, 2003 05:23 AM
Ya@inlinePRO
Aug 27, 2002 11:37 AM
