What spark plugs do I need to buy for my b20/vtec?
I got a b20 block and b16 head. What year and model car would I have to buy the spark plugs for? I bought bosch platinum 4's but I will be switching to NGK platinums. TIA
Re: What spark plugs do I need to buy for my b20/vtec? (Maximus)
i also need that info, but i would try to email crtvec.com or importbuilders.com for the exact part number, they must have used them before for a b20vtec
good luck in the swap
Re: What spark plugs do I need to buy for my b20/vtec? (Charlie)
Import Builders made crvtec.com. IB is making my motor for me but I don't want to bother them just to ask this question. That is why I am asking the people here on h-t tech to see if anyone else knows. On crvtec.com they said to get the bosch #4227 spark plugs but I was never able to find out what application that model number was for.
i emaild them about the price but that was only an hour ago. so how much is domniator package? i'f you don't mind sharing
Re: What spark plugs do I need to buy for my b20/vtec? (Halo)
I got 11.5:1 compression pistons. I am not too sure if I am going to open up the chambers to match my bore but if I don't then nothing should change.
[Modified by TreDEE, 10:28 AM 5/23/2002]
Re: What spark plugs do I need to buy for my b20/vtec? (Master Jedi)
As Master Jedi states above. There is no need for platinum spark plugs.
It is more important that you have a platinum credit card...so you can buy all the other expensive parts for your car
Re: What spark plugs do I need to buy for my b20/vtec? (Supersonic DC2)
I guess I was mistaken, when I asked jeff about crvtec.com he said he took part in making it.
Thanks Master Jedi I will try out those spark plugs.
i got a b20vtec (84.5mm rs pistons gsr head supertech flat valves retainers and springs itr cams deck and head been shave stock thickness cometic hg professional product im and 68m tb rmf headers ) motor has like 30 miles what spark plugs should i buy ??
thanks in advance
thanks in advance
thanks in advance
thanks in advance
You are busting on a poster from four years ago for "Bumping" an old dead thread... and you didn't offer any new or productive information.
NGK Iridium BKR6EIX-11 OR BKR7EIX-11 SPARKPLUGS FOR ALL MOTOR HIGH COMPRESSION WORKS GREAT.. FOR THOSE WHO NEED INFO!!!
That's better rookie... I agree on the heat range for most street driven multi-use type engines, although Iridium isn't necessary. Copper is fine... they just don't last as long as the Iridiums will.
4227, b20, b20b, b20vtec, bosch, built, compression, high, motor, plugs, recommendations, spark, type, vtec, wwwcrvteccom
