will a 9 LS ECu work on the B20B/Z?
plan on runign it on no obd , using 90 teg parts intake manifold, distbutor, injectors ecu. and my stock wiring harness how well will it run? will there be a check engine light on?
not running vtec head, but regular b20. thanks for any input?
Re: will a 9 LS ECu work on the B20B/Z? (Charlie)
Yes, it will work. You do not have to run the 90 b18a IM though, you can use somthing alot better if you choose.
Im not sure how it will run on a stock ecu, but you have either chip it or run a AFC to tune it correctly to the b20. Im sure it would run fine on a stock ecu though.
