Converting OBDII B20Z into ODBI
What is the best way to wire a B20Z into my 94 Si? I know I need a 94/95 LS ecu and intake mainifold, but should I get a OBDII to OBDI wiring harness or swap the distributor/injectors/etc for OBDI integra pieces. Also which header would be the best? I choose this motor for the low-midrange power and would like a header that emphasizes this powerband.
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
Re: Converting OBDII B20Z into ODBI (POS Hatchback)
i have a skunk conversion harness if you need one. i will have to figure a price if you want it.
Putting an OBDII b20z in my 92 LS (obd1), i just replaced the distributor with my old OBD1 distributor and used my old injectors as well. I think you need to do this with yours + the OBDI LS ecu.
RAMBO
05-04-2003 06:48 AM
