spoon ITR pistons in B18c GSR block!
New User
Im buying a Jdm Gsr motor with Lsd, and the VERY first thing i wanna do is put these spoon balanced ITR pistons in. I work at HOnda and the master tech would help me of course! Im just wondering if there is n e thing else that i need to do?
Re: spoon ITR pistons in B18c GSR block! (SlooowEG)
You'll need to bore and hone the block. I'd suggest that you also toss in some ARP rod bolts while your in the bottom end and maybe pick up some Type R rods if you can find a used set for a good price. I'd also replace all the bearings and buy a top and bottom end gasket kit. The gasket kits and bearings will probably cost you around $350 but it's good cheap insurance since you have no way of knowing how the engine was treated before you bought it.
dt4life
11-17-2004 10:30 AM
