Will 88-91 civic SI knuckles fit in 92+ civic?
first off, I have a spare set of 90 civic SI knuckles just lying around in the garage. Now, My hub on the 92 civic is fucked up and the splines are fucked up....you guys think I can just swap out the whole knuckle? I don't really want to take it to go get the hub pressed out....or will I have to press out the hub and interchange?
Re: Will 88-91 civic SI knuckles fit in 92+ civic? (Slow_ass_4dr)
The knuckle are different as the angle towards the upper ball joint is different between the two. It will cause a camber change, but I forget in what direction.
nc_motorsports
06-11-2006 09:55 PM
