B16 head + gsr block= lower compression with no modification ?
My dilemma:
I may purchase a gsr block w/ CTR pistons, but don't want to use an extremely high compression, so instead of using the GSR head, I was thinking of swapping for a B16 head/manifold to get a slighly lower compression (and better mani) What I am wondering is...
1) Will the B16 bolt up to the GSR block no problem, no modification ?
2) What is the difference in compression with a B16 head from factory vs a GSR head ? -0.2 ?
3) Will the B16 mani adversely affect the low end drivability before vtec ?
Thanks in advance
Thanks in advance
Re: B16 head + gsr block= lower compression with no modification ? (X2BOARD)
3) the low end power will not be hampered in any way if you went B16A head + intake manifold.
Re: B16 head + gsr block= lower compression with no modification ? (Katman)
Thanks guys...
The low end would be nice on the motor too, considering the higher comp pistons...
90B16aCRXsi
43
07-30-2008 08:50 PM
