VTEC Crossover Point
Old May 16, 2002 | 09:26 AM
mason's Avatar
Default VTEC Crossover Point
I'm thinking of getting my ecu chipped, and was wondering what RPM is the best for the VTEC crossover point? Is is better if it engages at 4800 or should it be higher?
Old May 16, 2002 | 09:36 AM
B_CRUZ!'s Avatar
Default Re: VTEC Crossover Point (mason)
it depends on your set up... which vtec head are you using with which cams? are you using a stock b18c1 intake manifold?
Old May 16, 2002 | 10:05 AM
InfamousRS's Avatar
Default Re: VTEC Crossover Point (B_Cruz)
On the topic of Vtec crossover. Is 5700 RPMs too high? Im have a mugen chiped p28 on LS/Vtec, the max rpm I plan on is 8000, so would it be better if the vtec crossover was lower?
Old May 16, 2002 | 10:38 AM
B_CRUZ!'s Avatar
Default Re: VTEC Crossover Point (InfamousRS)
i think 5700rpm is about right. you don't want it too low because imo it needs time to wind up... i have experimented with this before when i had a B18C1 civic coupe and a Field's vtec controller...
Old May 16, 2002 | 11:18 AM
kenji's Avatar
25 Year Member
For the smoothest transition with ITR/CTR/Toda specA cams a 5300 RPM VTEC switchover point is ideal. That is what I set my P28 program VTEC switchover at.
I have done a few hundred dyno runs with the aforementioned cams and this is the trend that I have seen.
-kenji
Old May 16, 2002 | 12:36 PM
B_CRUZ!'s Avatar
Default Re: VTEC Crossover Point (kenji)
i'll try that setting once i get my swap done this weekend...
Old May 17, 2002 | 04:54 AM
Mista Bone's Avatar
D Tranny Guru
yo Kenji, can you tune in a custom P28 SOHC proggy?
Like 4400 on/4200 off VTEC?
email if needed, I need just a bit more for 12 second ET's
honda_ek9
14
Jun 7, 2009 04:42 PM
LeesB
Sep 29, 2004 04:01 PM
skribblah
27
Aug 13, 2003 10:52 AM
SSA 1
Jul 27, 2003 09:41 PM
Malgerus
Jun 7, 2002 10:01 AM
