HELP!!!!! URGENT!!!! NEED TO KNOW SOON..... Vtec pressure switch!here is
There is 2 pins on the Vtec pressure switch, but there is only one wire comming form the A4 location on the ecu. Where does the secont pin lead to?
Re: HELP!!!!! URGENT!!!! NEED TO KNOW SOON..... Vtec pressure switch!here is (InfamousRS)
according to my obd0-obd1 coversion harness direstions...
"Connect the wire labled (6) the vtec pressure switch. it is located below the vtec solenoid. connect the number 6 wire to the to the blue wire on the pressure switch. the other wire needs to be connected to a good ground source. this plug is green and round with two pins"
the number 6 wire he is refering to would be coming from A4 on ecu
Re: HELP!!!!! URGENT!!!! NEED TO KNOW SOON..... Vtec pressure switch!here is (Jeff C)
Thats the same thing I was going to say . I just ran that wire yesterday actually. Those are the directions from blown90hatch's conversion, so just giving some credit .
i just finished my swap yesterday(B18C1 w/ skunk2 manifold) and yes. the black/blue wire needs to be attached to a good ground.
