trouble with mini-me
Old May 18, 2002 | 05:21 PM
noricercrx's Avatar
Default trouble with mini-me
I'm putting a d16z6 head on my d16a6 block. I got everything hooked up. It won't start... It's turning fine. and i think im getting a spark b/c at first there was a big flame that shot out my exhaust pipe. But its not firing up. any other things to try.
Old May 18, 2002 | 08:34 PM
Jared's Avatar
Default Re: trouble with mini-me (noricercrx)
dont think youre getting spark, know you are, pull out a plug and wire and see if it sparks, if it does, check for fuel pressure, if you have both of those, check the cam timing.
Old May 19, 2002 | 07:23 AM
noricercrx's Avatar
Default Re: trouble with mini-me (Jared)
I'm getting spark, I have fuel pressure, And I am for sure my cam timings on. Could it be something to do with my distributor.
Old May 19, 2002 | 08:22 PM
hatchBtype_R's Avatar
you should check everything with the distributor, could be the igniter try everything!! i have the same swap mini me and i found that it was the igniter
Old May 30, 2002 | 06:15 AM
mraudio13's Avatar
Default Re: trouble with mini-me (hatchBtype_R)
i did a mini-me swap and it sat for 2 months because i could not start it, my white wires on my distributor were switched, so my ignitor was not getting power. switched them and it started right up.
matt
tundra2000
Jun 8, 2010 03:27 PM
Sturg
Oct 27, 2009 12:04 AM
egtony
10
Sep 4, 2009 01:44 PM
PalmSpringsDelSol
Jan 21, 2008 05:11 PM
noricercrx
May 19, 2002 07:25 AM
