98 b18c1 in 92 hatch
New User
Will I need to buy a obd II to obd I converter harness? I was thinkin about Skunk2 is that good? Will there be any other problems puttin it in? Thanks...
Re: 98 b18c1 in 92 hatch (Si HaTcHBaCK)
Nope the motor will still plug rite in with no problem. Wire your interior wiring harness for a KS and IAB solenoid that's about it. Just run an OBD 1 P72 ECU.
The correct way to put it is like this....
If you want to run an ODBII ECU, then you need a converter harness. If you want to run an ODBI ECU then you don't.
4wsB21a
02-12-2002 08:10 AM
