b20 vtec/ lsvtec...
Old May 19, 2002 | 04:28 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default b20 vtec/ lsvtec...
For LS vtec, do you need custom pistons like b20 vtec?
Old May 19, 2002 | 04:55 PM
allmtr's Avatar
Default Re: b20 vtec/ lsvtec... (GapxGuy)
you can if you want, but no
Old May 21, 2002 | 11:19 AM
EVOCELICA's Avatar
New User
I'm using ITR's but you can use stock ls pistons if you like
Old May 21, 2002 | 11:41 AM
SiBirdie's Avatar
Default Re: b20 vtec/ lsvtec... (EVOCELICA)
lsvtec you dont need custom piston. cause a b18a/b block and b16/b18c/b18c5 all have the same bore size. Which mean same piston size. If I were you i'll either go with JDM ITR piston in a lsblock with b16head give you like a 11.4 cr. CTR piston in a ls w/b16 give you a 12.4.
good luck!
vtechachey
Mar 11, 2008 02:34 PM
cbabyby
Mar 10, 2007 08:38 PM
b18_racer805
Oct 13, 2005 10:48 AM
ALLMOTORJ
Mar 16, 2004 07:54 AM
tvrcrx
Mar 6, 2004 05:04 PM
