H22/Civic dudes....read.
i finished my H22A <<< JDM swap into my 92 civic cx. now, the motor cranked over which is great. i cranked it w/o fuel or spark to get some oil distributed. then i plugged the injectors in and put the spark plugs and wires in. the motor didn't start and i got a CEL code 15 which is ignition output signal. here's the deal. i don't have the stock H22 coil. i'm using an MSD Blaster 2 coil. it has a (+) and (-) terminal of course. where should i hook these up? the directions that came with the coil don't have a description for my setup. i don't have an MSD Ignition box. i do have the 4 Plug harness for the stock coil on my motor but it only has 3 of the 4 wires in it. right now, i have the two terminals on the MSD coil hooked up to 2 of the wires on that 4 plug harness. i don't know if that's right or not.
Mikey3000
05-18-2002 09:11 AM
