Crank Position Sensor
Old Sep 8, 2003 | 03:39 PM
spoooonfed's Avatar
Default Crank Position Sensor
I'm swapping a 95 B18B block onto my 2000 B18B head, to be reinstalled into a 2000 integra manual LS . Now my mechanic says the 95 B18B block doesn't have a crank position sensor, so It can't be used.
I don't know much about crank sensors so any information or tips would me much appreciated.
thanx
Old Sep 8, 2003 | 04:30 PM
inspyral's Avatar
The CKP is in the oil pump. Just use a newer oil pump with your 95 block.
Old Sep 8, 2003 | 06:34 PM
racecarpete's Avatar
Default Re: (inspyral)
what he said.
Old Sep 8, 2003 | 07:26 PM
spoooonfed's Avatar
Thanks for the quick replys.
I'll be using a 98 oil pump. Will this bolt up to the 95 block and will this pump connect to the sending unit correctly?
Old Sep 8, 2003 | 07:41 PM
inspyral's Avatar
Default Re: (spoooonfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoooonfed &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the quick replys.
I'll be using a 98 oil pump. Will this bolt up to the 95 block and will this pump connect to the sending unit correctly?</TD></TR></TABLE>
It'll bolt up. The oil pump has nothing to do with the oil pressure sending unit. The newer pump w/ CKP should plug right into the CKP plug on your harness.
Old Sep 8, 2003 | 08:05 PM
spoooonfed's Avatar
inspyral, you've helped me out big time in the past frew days. You helped with the charcoal breather box the other day. I really appreciate your quick replys.
If u ever need an heart transplant, I got you. You might have to hone your aortic valve. The say blak guys' hearts flop more blood/lbs
Jus playin ..
turbosol_16
Feb 1, 2007 08:48 AM
nighttrain33
Oct 3, 2006 07:30 PM
slowteg550
May 21, 2006 03:12 PM
warwagon
Jan 11, 2005 05:14 PM
Turbo Lude SH
Nov 4, 2002 11:30 AM
