d16z6 head on d15b2?
Old Sep 7, 2003 | 01:27 PM
green91's Avatar
Default d16z6 head on d15b2?
Ive searched all around, havent been able to find an answer, sorry if ive overlooked it! is it possible to put the sohc vtec head on d15b2 block? bolt right up? any results if its possible? thanks in advance
Old Sep 7, 2003 | 05:48 PM
3RdT's Avatar
Default Re: d16z6 head on d15b2? (green91)
yes it would bolt rite up. this set up is called a mini me. puttin on a vtec head on a non vtec block would give u a lil more hp. try searching under mini me.
Old Sep 8, 2003 | 08:14 AM
green91's Avatar
Default Re: d16z6 head on d15b2? (3RdT)
thanks, i knew the d16z6 vtec head would bolt onto the Si block (d16a6) but i wasnt sure if it would bolt onto the d15b2 because its a 1.5liter. Has anyone on here actually put the head on the 1.5 block? what kinda 1/4 miles could i expect.. mid 15s? thanks
Old Sep 8, 2003 | 10:42 AM
Andres-eh2's Avatar
try high 16's from a stock mini-me and a 1.5L bottom
Old Sep 8, 2003 | 01:17 PM
Lightning Lover.'s Avatar
Default Re: (EGEESIX)
what kind of car is it going in? if its a lighter car, it would be able to hit lower 16's if yuo can drive.
Old Sep 8, 2003 | 02:22 PM
green91's Avatar
Default Re: (Dr. Physics)
Its going in a 1991 DX hatchback. the motor has 144,000 well maintained miles. I plan on running a compression check on it soon, and as long as the compression is still good im going to find a d16z6 head and swap it on. I will be happy with 16s, the car is just a small project car, i dont plan on racing it - just want it to be quicker, and i like the idea of VTEC even though it probably cant even be heard on a SOHC motor. Is there really that big of an advantage to using an apex vafc over just a rpm switch? im tryin to keep the cost low on the project. i plan on getting si manifold preferably complete with injectors.. etc, and a Si ecu. i will also be running a header, full custom exhaust and intake. I think this will turn the car into a respectable, streetable dx! thanks so far for the help. also, if anyone who has done the swap onto a d15 would like to, your impressions on the swap are welcome.. thanks!
Old Sep 8, 2003 | 02:55 PM
Default Re: (green91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green91 &raquo;</TD></TR><TR><TD CLASS="quote">Its going in a 1991 DX hatchback. the motor has 144,000 well maintained miles. I plan on running a compression check on it soon, and as long as the compression is still good im going to find a d16z6 head and swap it on. I will be happy with 16s, the car is just a small project car, i dont plan on racing it - just want it to be quicker, and i like the idea of VTEC even though it probably cant even be heard on a SOHC motor. Is there really that big of an advantage to using an apex vafc over just a rpm switch? im tryin to keep the cost low on the project. i plan on getting si manifold preferably complete with injectors.. etc, and a Si ecu. i will also be running a header, full custom exhaust and intake. I think this will turn the car into a respectable, streetable dx! thanks so far for the help. also, if anyone who has done the swap onto a d15 would like to, your impressions on the swap are welcome.. thanks!</TD></TR></TABLE>
i will be starting mine later on this week. i should be getting the new head and manifold on friday, hoping to be done by next mondayI(crosses fingers).
Old Sep 8, 2003 | 04:15 PM
green91's Avatar
If i do head-only swap, how much shoudl i expect to spend? so far im thinking (hoping??) it will be about like this:
$150-$200 to do full MPFI conversion
$150?? for the d16z6 head
$100 for timing belt, serpentine belts, misc junk (wiring oil coolant etc)
so maybe $400-$500 to get my dx into the 16s with vtec.. i also plan to eventually get an apex vafc to get the correct fuel amount for vtec but $200 is alot of money to cough up for a little blue and silver piece of plastic
Old Sep 8, 2003 | 04:23 PM
3RdT's Avatar
if u spendin that much money.. u can juss buy a jdm d15. has a more aggressive cam n a lsd tranny. n if u can shift correctly u can beat slightly modded b16's
Old Sep 8, 2003 | 05:17 PM
B18Cej1's Avatar
Default Re: (3RdT)
damn too bad ur in GA, i would sell you my mini me setup.d16z6 head d15b7 block
Old Sep 8, 2003 | 05:29 PM
3RdT's Avatar
Default Re: (whitericeEG)
how much u planin to sell ur mini for?how many miles?
Old Sep 8, 2003 | 05:54 PM
green91's Avatar
Default Re: (3RdT)
does the mini-me swap really cause many problems?
Old Sep 8, 2003 | 10:10 PM
B18Cej1's Avatar
i bought the car with the mini me in it, the car had 111,000 miles on it and i put on bout 30k. the motors past is kinda shady..(but i do have maint records from the time i had bought the car.) i will be nothing but completely honest when asked about this motor. ill sell everything below for $150
-d16z6 head, fuel rail, intake mani, etc etc
-d15b7 block (20k ish miles put on by me)
-d series hydro tranny (dont know which one) (tranny SHOULD be replaced or repaired **bad synchros) clutch slipping too
-shift linkage
-axles
-p28 ecu
**head gasket leaked but wasnt completely blown (got heated every now and then)
i never ran nitrous so i doubt its cracked (take the head to a machine shop)
-shiny blue oil cap
any other questions feel free to ask. i could take aprt the setup and part out everything and make a LOT of money i just dont have a garage or the time to do it. this is a good opportunity for anybody. engine needs a good home. i dont want to have to take it to the recycling yard.
Old Sep 9, 2003 | 10:12 AM
3RdT's Avatar
r u willin to trade for parts? n sorry if u think im tryin to jack ur thread
Old Sep 9, 2003 | 10:20 AM
B18Cej1's Avatar
Default Re: (3RdT)
trades.. depends on what. let me know...
Old Sep 9, 2003 | 09:26 PM
B18Cej1's Avatar
didnt see the link.. what you have im either selling also or already have. are those b16 cams oem or aftermarket?
Old Sep 10, 2003 | 11:07 AM
Zakar's Avatar
for 500 bucks you could Spray
Old Sep 10, 2003 | 05:38 PM
Default Re: (MusclecarGuyhasHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MusclecarGuyhasHonda &raquo;</TD></TR><TR><TD CLASS="quote">for 500 bucks you could Spray</TD></TR></TABLE>
yeah you could, but your engine wouldnt last long, and wouldnt make much power with the restrictive stock parts. also, you cant do that with the stock dpfi w/o some other kind of fuel management or with out it being so ghetto you would run the risk of blowing the motor.
you could just run your stock block and invest that 500 into a turbo kit and mpfi parts. check out ebay, they sometimes have complete kits for under 500.
Old Sep 10, 2003 | 05:59 PM
djcaseanova's Avatar
Well, I have a d15b2 and a d16y8 that WILL NOT WORK because of the timing and mainly the water pump. That is a 2 tooth difference and is a complete pain in the ****.
If anyone's interested let me know I have a D16Y8 head to sell...
Old Sep 10, 2003 | 06:11 PM
green91's Avatar
Default Re: (djcaseanova)
im just lookin for a local head, i dont wanna pay shipping on whatever it actually weighs if i can just get it locally. im not in a hurry, i hope to have all the parts accumulated in 2 months or so.. but im seriously looking for pm6 ecu and mpfi conversion parts, i think for the time being the hp increase from mpfi would help alot until i can get vtec.
boosting sol
14
Sep 6, 2009 03:42 PM
_BEN_
Feb 10, 2005 07:13 PM
whitey94hb
Nov 9, 2004 06:52 PM
fivil
Dec 30, 2002 05:22 PM
autoEXturbo
Nov 27, 2002 05:23 AM
