What are the REAL specs on my JDM B16A SiR-II?
I couldn't find many posts about this... I have a truckload of information about USDM B16's... bore, stroke, cam profiles, compression ratio, transmission gear ratios, etc... but can anyone give me these numbers for my 1994 JDM B16A SiR-II, or know where to go to look?
Thanks,
zelif
Thanks,
zelif
Re: What are the REAL specs on my JDM B16A SiR-II? (zelifcam)
everything is the same except .2 compression increase and a rated 10hp more.
you know you could just make 1 thread with all these questions instead of 6 seperate ones.
Re: What are the REAL specs on my JDM B16A SiR-II? (Kamin)
sorry for the multiple threads...
i know of this supposed .2 compression point gain and the horsepower thing. but what i want to know is how this is done, what is different about the engine? i need all the specs....
ah, good deal. do you know if the pistons are domed, or have a shorter height? also, dosen't the JDM B16 rev higher? what is that about? is it balanced more finely?
