b16swap, CEL, help
Old Aug 29, 2003 | 07:12 PM
DAMCOOLDAV's Avatar
Default b16swap, CEL, help
Hi guys, i'm new hear but here you are the best. I just did a b16 swap today and everything is pretty good except my CEL is on. Its throwing a code 3, which is the map sensor, but the connector looks fine and the vacuum lines look fine and this was never a problem before the swap, and i'm damn sure my mechanic didn't even have to touch the map sensor while swapping although he did take out the a/c and the vacuum lines for it on that cylinder shaped thing on my 91 GS, can anybody help me out?
Old Aug 29, 2003 | 08:59 PM
CanuckCRX's Avatar
New User
Default Re: b16swap, CEL, help (DAMCOOLDAV)
Just swap in another map sensor from another Honda and see if that takes care of it.
Old Aug 30, 2003 | 07:18 PM
DAMCOOLDAV's Avatar
Default Re: b16swap, CEL, help (CanuckCRX)
the vacuum cylinder for the a/c had to holes but i plugged both with a hose, and it still didn't work, i would like to try to get away from using another sensor for now, i mean why would it go bad just when i did the swap, makes no sense. Could tiny little cracks in a hose really make that type of a difference?? can anybody else help me!?
Old Aug 31, 2003 | 09:03 AM
DAMCOOLDAV's Avatar
can anybody help me!!?? it can't be my map sensor why would it go bad just cuz i did a swap?? everyone thinks its a vacuum line but i can't find out why they are all hooked up.
Old Sep 1, 2003 | 05:26 AM
VTECVillain's Avatar
Make sure the TPS and MAP sensor plugs aren't switched, it's easy to do since they are close and the same style plug. If that checks out then go over the vacuum lines, then troubleshoot the wiring for the MAP. If that's all good then you''ll need to replace the MAP, you can use one from nearly any year Honda/Acura.
snidbits
Feb 11, 2011 03:19 PM
JasonST
Apr 26, 2006 07:36 AM
Punker1234
Feb 4, 2006 01:20 PM
sakums20
Apr 29, 2004 02:40 PM
