I need a Motor mount kit!
I was wondering if anyone knew where I could order a decent motor mount kit for for my 94 coupe w/ gsr swap. I 've seen the Hasport kit pretty much everywhere but don't have that much money. Also is it even worth it to buy any other kit than the Hasport? Please help, my car shakes like crazy.
I want to replace all the mounts in my car right now. I have the Prothane mounts and the inserts and they are coming out. For the driver side top I have the stock, and I am on my second one. I don't think that the stock mount can handle launching my car.
Ok at least you have a valid reason, not like "CuZ I WaNt ThEm!"
hasports are great if you can afford them. the best. the poly inserts may LOOK like they are comming out, but are actually wedged in there solidly.
if you want to save a couple bucks, just pick up the rear t bracket mount.
if that one is semi-solid it will decrease alot of wear on the other mounts.
Are you saying just buy the "Hasport" rear t bracket mount? If so, where can I buy it. Yea, I rather save my money for my motor than buy a motor mount kit, but since I'm in the predicament of having to buy a new motor mount I'd rather just do it right the first time.
yea you can get away with just using the hasport rear mount if you want, that is the one that holds the engine the MOST when you rev and launch (prevents forward/backward rotation)
its an upgrade over all stock's but not as good as all the hasports.
Thanks for your help Kamin. One more question to you or anyone else, Anyone use the HCP Engineering kit off JDM ****? If so, likes?Dislikes?
I've heard the HCP kit is great. Many people say it's right up there with HASport. JDMShit right now is also having a sale on them, so that might be a good way to go. I would suggest buying the whole kit, even if you'd rather spend the money on your engine. This is because you should probably do it right the first time, or you'll keep running into trouble. Plus the more money and power you put into your engine without fixing the problem you have now, the more the shaking is going to get worse.
-JDMSaint- aka Adam
-JDMSaint- aka Adam
yep i have a buddy using the hcp i feel there just as good as my hasport, jut hit up newman from jdmshit he will hook u up
ohh and just wodering whats ur set up? sounds fast
Jockobo
11
Aug 31, 2005 08:17 PM
