anyone who's swapped an H22A themselves, please answer question.
Old 09-08-2003, 06:50 AM
the_eyecon's Avatar
Default anyone who's swapped an H22A themselves, please answer question.
Did you change your distributor? I used my H23 harness (since the other was JDM) and there is no spark to the distributor, and I think it's because it has an internal coil, and my harness is set for an external coil, so it's not firing up...think so? Thanks.
ps. it's going in a lude.
Modified by the_eyecon at 5:29 PM 9/8/2003
Old 09-08-2003, 08:46 AM
b17gsr's Avatar
I used the H22A distributor that came with the motor for a 94 Teg. Both where OBD1, so plug and play.
Old 09-08-2003, 09:35 AM
MPower332TI's Avatar
Default Re: (b17gsr)
Just check all the wiring on each side of the dist and make sure it all matches up. You should have to change a couple wires around to make it work right. Just compare the H23 wiring with the H22 wiring.
Old 09-08-2003, 11:36 AM
fasterplease's Avatar
Default Re: anyone who's swapped an H22A themselves, please answer question. (the_eyecon)
I had to use a distributor from an H22, but my engine (also JDM H22A) went into an accord.
Old 09-10-2003, 06:00 AM
BUCKO5's Avatar
Default Re: anyone who's swapped an H22A themselves, please answer question. (fasterplease)
i used the h22a distributer, that went in my 94 teg...
Old 09-10-2003, 12:28 PM
fastwanabe's Avatar
Default Re: anyone who's swapped an H22A themselves, please answer question. (BUCKO5)
I/m actually going through this right now with a swap from a friend, I'm just goint to change the internal from the H22 distributor to a civic internal coil internals hopefully I wont have to wire anything else up.
Old 09-10-2003, 12:39 PM
HotWheelz's Avatar
Default Re: anyone who's swapped an H22A themselves, please answer question. (fastwanabe)
the shaft isn't the same, everything else is.
Old 09-10-2003, 02:25 PM
poison's Avatar
I just used my JDM prelude obd1 distributor, plugged right up.
You will have to change the coil wiring to the external coil, or you may also convert your harness to the internal coil and use the JDM internal coil distributor.
Old 09-10-2003, 06:01 PM
accordm3's Avatar
accord single cam vtec dist is the same as the h22a obd1
92civtegra
05-04-2009 03:18 PM
NukeeZoid
05-25-2006 10:15 AM
Stoich EG2
12-15-2004 06:35 AM
92whiteSi
08-11-2004 08:53 PM
Quick Reply: anyone who's swapped an H22A themselves, please answer question.
