Am I starving my B18C with my stock....
Re: Am I starving my B18C with my stock.... (SPOONfdEK)
stock pump with proper ECU and injectors you should be more then fine, but once you start making more then 180+whp then it would be a good investment.
Re: Am I starving my B18C with my stock.... (eg6ajk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">stock pump with proper ECU and injectors you should be more then fine, but once you start making more then 180+whp then it would be a good investment.</TD></TR></TABLE>
I'd also say the same.
If you upgrade, you can upgrade to ITR or also Walbro 190 lph or 255 lph.
likely lean in the upper revs,
any dohc vtec civic/teg fuel pump is drop in.
used they are cheap, like $40.
