H series motor and the front motor mount
When swapping a H series in a hatch/del sol/civic you only use 3 motor mounts... The tranny side, rear, and drivers side. However, when honda designed the prelude they chose to use 4 motor mounts. Tranny side, rear,drivers, and a front mount as well.
I am having a custom manifold made for my turbo setup and the front motor mount is somewhat in the way. So I was wondering if any of you guys knew if it is ok to remove it or not. Personally, I do not think thats the best idea in the world due to the load that will be put on the other 3 mounts as well as having a motor that will have over 350 ft lbs of torque to the wheels.
I can have the manifold redesigned and go with a top mount turbo instead, but I am curious as to if it is ok to ditch the front motor mount on a 4th gen prelude.
Thanks.
Thanks.
Re: H series motor and the front motor mount (GudeH23a)
The front mount is used mostly as a torgue mount. In Civic usually the mounts have urethane bushings so movement is less prone than in a lude or accord. If you are going to not use the mount then I would suggest upgrading the bushings in the other 3.. Otherwise that sucker is going to move..
i have an h22a ek with the drivers side gel mount and i swear, with the car on the hoist and you nail it the thing doesnt move at all.
onyx00
09-24-2004 01:00 PM
