????'01 GSR into a '96 Del Sol?????
Re: ????'01 GSR into a '96 Del Sol????? (ntegls)
assuming the del so is not DOHC VTEC?
u need the complete engine from the teg..
-teg rear mount
-teg tranny front mount
-harness is fine..have to sire for vtec if u dont have it
-shift linkage from dohc vtec del so
-axles from the teg..
-that should be all the major things...
-teg rear mount
you also need a p72 obd2 ecu if you want the IAB to work. Or you could just go with a skunk2 manifold and use a chipped p28 with a obd2 to odb1 conversion.
nekoabandoned
03-19-2006 08:31 PM
