B18B swap parts. How to identify?
I found a B18b1 longblock in a local junkyard. It's missing a dizzy, and others accesories like alternator, etc...
I need to know how to identify visually the parts I need to complete the longblock. There are many scrap parts laying around, so I need specifics.
-Any dizzy that will fit (from any of these engines: B18A, B18B, B20Z, B20A, etc)
-Hydro tranny (How do I identify a hydro from a cable tranny?)
-Alternator
-Power Steering Pump
-A/C pump
Any pics will be great.
-Alternator
-A/C pump
Re: B18B swap parts. How to identify? (jetpilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jetpilot »</TD></TR><TR><TD CLASS="quote">I need to know how to identify visually the parts I need to complete the longblock. There are many scrap parts laying around, so I need specifics.
-Alternator
-A/C pump</TD></TR></TABLE>
You might as well match the OBD of the distributor to the OBD you'll be using in the car to avoid splicing/repinning.
Hydro tranny will have a slave cylinder on the front, if missing you can still tell by the engagement fork arm. The cable tranny will have an arm on the front with a bend and mount for the clutch cable. Look around on here for some tranny pics and you should have no problem telling the 2 apart.
Alternator shouldn't be an issue, just match the OBD to avoid splicing.
You'll need a 94-95 Integra power steering pump if I'm not mistaken. I don't own any cars with power steering and 2 of the swaps that I've done (both B16A's in OBD1 cars) came with a power steering pump that matched the lines and worked perfect.
If you're dumping the motor into a Civic you won't need the A/C compressor rather use the stock Civic one with a Del Sol VTEC S/C bracket.
-Alternator
