Need input on cv shafts "out of alignment" after 92 civic hatch 95 GSR Swap
I have a 92 Civic Si Hatch with a GSR swap. The cv shafts do not line up coming out of the tranny and half shaft when connecting to the hubs. I have been told that is this is a bad condition that can lead to premature cv failure. Do any of you have this problem.
If you look underneath your car straight up. Notice if the shafts do not go straight to the hub... Thank you for the input.
Another thing I was told is that the cv's or halfshaft might not be the proper length. Any input??
Thanks.
Thanks.
Re: Need input on cv shafts "out of alignment" after 92 civic hatch 95 GSR Swap (95GSRRacer)
if u used the grs axels thats what ur prob is, get ur hands on some del so vtec axels(napa,pepboys,discount auto,) they can hook u up, or if ur gunna make power then just get a nice set of dss axels, for the time being see if just getting the car allined work for ya good luck keep us posted
Re: Need input on cv shafts "out of alignment" after 92 civic hatch 95 GSR Swap (SlOwCrXbUtUbNbEaT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlOwCrXbUtUbNbEaT »</TD></TR><TR><TD CLASS="quote">if u used the grs axels thats what ur prob is, get ur hands on some del so vtec axels(napa,pepboys,discount auto,) they can hook u up, or if ur gunna make power then just get a nice set of dss axels, for the time being see if just getting the car allined work for ya good luck keep us posted </TD></TR></TABLE>
???wrong axles? I use the GSR ones no prob. am i missing something?
Re: Need input on cv shafts "out of alignment" after 92 civic hatch 95 GSR Swap (Turbo E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E »</TD></TR><TR><TD CLASS="quote">
???wrong axles? I use the GSR ones no prob. am i missing something?</TD></TR></TABLE>
Yeah. I am missing something... Someone to post on this thread that know what I am talking about...
Please help!
Please help!
You should have no problems using the GSR axles/int. shaft with a 92 hatch. This is the proper combo to use and there really is no better setup. If you are using aftermarket rebuilt axles then that might be your problem, or you've excessively lowered the car, your tie rods, ball joints and/or wheel bearing are shot, many possibilities.....
Re: Need input on cv shafts "out of alignment" after 92 civic hatch 95 GSR Swap (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain »</TD></TR><TR><TD CLASS="quote">You should have no problems using the GSR axles/int. shaft with a 92 hatch. This is the proper combo to use and there really is no better setup. If you are using aftermarket rebuilt axles then that might be your problem, or you've excessively lowered the car, your tie rods, ball joints and/or wheel bearing are shot, many possibilities.....</TD></TR></TABLE>
Thank you very much for your input. good to know I have the right stuff for sure. The car is quite low and I have done some mods to optimize the performance for autox and track days. Thank you again.
I do wonder if I am the only one who has this problem. Or maybe I am just the small few who is aware that there is a problem?
mattmkng
12-13-2006 04:33 PM
InJ3cted
11-24-2006 04:15 PM
