problems with b16a swap
Old Sep 4, 2003 | 02:52 PM
zlambe's Avatar
Default problems with b16a swap
I just put in my new fuel pump and went to go see how it was running and when I opened it up around 6000 the rev limiter came on and the car shut off with the check engine light on. It will not crank up and the check engine light stays on .The Vafc will not come on . I tried another ecu and still nothing happened, I also unhooked the vafc and still nothing. anyone have any ideas ?????????
90 civic hb with b16a Msd digital sci box msd coil Apexi vafc Walbro 255 fuel pump,
Intake and exhaust. PR3 ecu
Old Sep 4, 2003 | 05:22 PM
projecthybrid04's Avatar
Default Re: problems with b16a swap (zlambe)
check fuel pump wires, also check the wiring to ignition also make sure the battery terminals are good
Old Sep 4, 2003 | 05:55 PM
Kamin's Avatar
Default Re: problems with b16a swap (projecthybrid04)
try to pull the code by jumping the service connector above the ECU
for refrence on how to do that use the search button.
Old Sep 4, 2003 | 08:22 PM
zlambe's Avatar
I just went out and messed around with it And its not firing or getting fuel pressure, the ECU is not getting any power so i think thats why its not firing or getting any fuel. But I cannot figure out why its not getting power . The ecu or the hazard fuse is not blown.Help
Old Sep 4, 2003 | 10:24 PM
zlambe's Avatar
I was wonderring if I can run a wire from the underhood fuse block,ecu fuse,to the power wire on the ecu. the ecu fuse is getting power but not at the ecu.Any help would be great.
Ruben19
Jan 8, 2006 09:38 PM
Ri5e
Jul 5, 2005 01:16 PM
extrmeboost
Aug 31, 2003 05:10 PM
hybridbmw
Jan 8, 2003 11:15 PM
