ls/vtec help!
Old Sep 2, 2003 | 12:37 PM
crzyB16Agirl's Avatar
New User
Default ls/vtec help!
I'm moving on from the world of basic b16as and going on to hybrid motors. I'm planning on building an ls/vtec using a b18b block and either a b16a2 head or b18c1.
First, which head would be better?
Second, I intend to drop the motor into a 92-95 hatch, gut it, roll cage, suspension upgrade, etc, etc, etc... I plan on using a t3/t4 turbo on the ls/vtec to gain added horsepower and have this be my "track only" car.
I'll be able to do all the work myself, boring, honing, balancing, you name it (I have all the equipment available to use). What set up should I use to build the quickest and a somewhat reliable (since money doesn't grow on trees) track car? Type of cams, crank, pistons, etc? Also, what size bore/sleeves should I do?
Thanks for all your time.
Kasey
Old Sep 2, 2003 | 01:21 PM
Rukusmasta2's Avatar
Default Re: ls/vtec help! (crzyB16Agirl)
peopel say the b16 is better cuz it flows better or u could port n polish the b18...u should def build the whole motor up wit new pistons,rods,valve springs, etc. u know...
Old Sep 2, 2003 | 03:01 PM
skribblah's Avatar
Default Re: ls/vtec help! (Rukusmasta2)
read the post in my signature and you will gain ALOT of info about ls/vtecs and what makes them tick.
Old Sep 2, 2003 | 03:52 PM
poison's Avatar
I would recommend using the PR3 (B16 or ITR) head with the LS/VTEC, although a P72 (GSR) head would be just fine.
I'd go 84mm with GE sleeves and 12.5 CR That's just me though.
Old Sep 2, 2003 | 08:16 PM
LSVTEC96HB's Avatar
Default Re: ls/vtec help! (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">
I'd go 84mm with GE sleeves and 12.5 CR That's just me though.</TD></TR></TABLE>
wow, 12.5 CR with a turbo? you're brave. I'd probably stay in the neighborhood of 10.0:1, then bulletproof it and boost the crap out of it, run 10s why not?
Old Sep 2, 2003 | 08:41 PM
poison's Avatar
Default Re: ls/vtec help! (LSVTEC96HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC96HB &raquo;</TD></TR><TR><TD CLASS="quote">
wow, 12.5 CR with a turbo? you're brave. I'd probably stay in the neighborhood of 10.0:1, then bulletproof it and boost the crap out of it, run 10s why not?</TD></TR></TABLE>
Whoops. My bad. I'm an NA *****
DA STRIKER
Dec 2, 2010 02:45 AM
mysterysktr7
Sep 11, 2010 08:12 AM
TougeCoupe
May 29, 2005 05:58 PM
No
Mar 18, 2004 03:17 PM
X2BOARD
Jun 11, 2001 11:52 AM
