2k gsr motor into 94 ls, any problems?
I was just wondering if all the harnesses will plug up. I just did an ls into my friends ek and it wasnt a problem. I know i just have to run the wire for the vtec. I bought a service manual for my car and it has alot of nice descriptions.
Re: 2k gsr motor into 94 ls, any problems? (tremor86)
If you use the 00 GSR harness it will plug in at the shock towers and you can retain all of the OBD2 components on the motor. Then get an OBD1 P72 ECU and the only wiring you will need to do is the VTEC, VTEC pressure switch, Knock and IAB.
If you use the OBD1 LS harness then you will need to repin/rewire the distributor, injectors and alternator or replace those with OBD1 parts for plug and play.
