99 SI (B16a2) swap into 93 civic SI
Just wondering how i'm gonna have to wire this swap up. I'm thinking use the 93 civic harness and modify/ swap pins to the OBD2 distributor and fuel injectors and run a chipped p28 ecu. I know i'm gonna have to swap the timing belt side motor mount bracket and motor mount to 94 -00 integra parts. Will the 99 Si rear bracket work or will i need the 94-00 integra rear bracket? Anyone done this swap before or have any advice about wiring and the rear bracket? Thanks
Re: 99 SI (B16a2) swap into 93 civic SI (SiR831)
You need the 94-01 Integra rear bracket, the 99-00 Si bracket will not work. As for wiring, to make it almost plug and play, get yourself an OBD2 Integra GSR or Type-R engine harness. That way the distributor, alternator and injectors will plug in without rewiring plugs. Of course you can reuse your stock harness and rewire those parts where needed. A chipped P28 or P30 ECU would be the best ECU choices.
perfectsphere72
03-21-2014 09:33 PM
blackccoupe
03-12-2014 08:52 PM
white_crx_guy
Texas -OK -LA (Sales)
12-19-2008 04:35 AM
