b20 head on b16 block
Old Sep 8, 2003 | 07:33 AM
Bongnak's Avatar
Default b20 head on b16 block
hey guys i did a search and that didnt really come up with a definite answer. Has anyone done this? will it work i kinda looked at the gasket and it kinda matches. the only problem i see is the head pins they are on the opposite sides. I got these parts for free they were from a crvtec. tia!
Old Sep 8, 2003 | 07:57 AM
skribblah's Avatar
Default Re: b20 head on b16 block (Bongnak)
you will be making close to no real power with that setup, plus i think there is an issue with the bowls of the head being too large for the 81mm bore of the b16.
Old Sep 8, 2003 | 08:11 AM
AussieK24's Avatar
Default Re: b20 head on b16 block (skribblah)
Sell the head to a smelter yard and buy a B16 head. 135 whp instead of....oh....65?!?!?!?
Old Sep 8, 2003 | 09:28 AM
96hb's Avatar
Default Re: b20 head on b16 block (AussieB20vtec)
I thought that swap went the other way around? B16 head on B20 block...
Old Sep 8, 2003 | 12:07 PM
Bongnak's Avatar
Default Re: b20 head on b16 block (96hb)
kool guys thanks a lot i was going to turbo it anyways but i guess. how about an ls head any issues there?, dont have money for a vtec head.
Old Sep 8, 2003 | 04:43 PM
Eyewitness's Avatar
No Point....a b16 head on a B20 block is what you want...and if you dont have money for a vtec head the money you are spending will be a waste....either get a b16 head for the b16 block i assume you have. Or sell the b16 block and but something else.
Old Sep 8, 2003 | 05:00 PM
PushinRedline's Avatar
aint worth ur time. Just get a vtec head. If no money then wait a while until u can save up.
Old Sep 8, 2003 | 05:36 PM
ProJectCvic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bongnak &raquo;</TD></TR><TR><TD CLASS="quote">kool guys thanks a lot i was going to turbo it anyways but i guess. how about an ls head any issues there?, dont have money for a vtec head.
b20 head very similar to Ls head....no point
Old Sep 9, 2003 | 12:05 AM
Bongnak's Avatar
Default Re: b20 head on b16 block (ProJectCvic)
ok thanks guys....anyone sellin a vtec head in so cali ?
Old Sep 9, 2003 | 04:18 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bongnak &raquo;</TD></TR><TR><TD CLASS="quote">hey guys i did a search and that didnt really come up with a definite answer. Has anyone done this? will it work i kinda looked at the gasket and it kinda matches. the only problem i see is the head pins they are on the opposite sides. I got these parts for free they were from a crvtec. tia!</TD></TR></TABLE>
A reversal CRVTEC??? That's like a B16noTEC
Old Sep 9, 2003 | 06:35 AM
nominous's Avatar
If you have the bits and it aint going to cost you do it for the hell of it!
What else do people do with the spare head and bottom end after building a B20VTEC ?
Old Sep 9, 2003 | 06:44 AM
AussieK24's Avatar
Default Re: (nominous)
Cause it wouldn't be worth the assembly time and fitting time and gasket cost. A standard D series would kick it's ***
Old Sep 9, 2003 | 07:16 AM
yellaboi's Avatar
Default Re: (AussieB20vtec)
B20 and Ls heads are exactly same B20 combustion chamber is also 81mm. There is no use in this swap, would require blocking oil passages on block, would not make much power. Get vtec head or B20/ls block for a complete engine.
Old Sep 9, 2003 | 09:08 AM
Bongnak's Avatar
Default Re: (yellaboi)
I a d series person, and know enough about them, but i dont about b series' just yet. I really want to turbo the b block whether it be a ls head or b16 head. if i were to get a b16 head would it be ok to run obd0 and have an external vtech switch? i havent looked into ths yet but the connectors look similar if not the same. the ecu i will use is an extra pr4 i have chipped for ghettodyne. that way i can reburn the fuel map and timming to run proper fuel and timming and wat not.
oh also just a question ive always had about vtec's, will vtech engage under part throttle at high rpm or only at wide open throttle?-for stock ecus- and with the msd switch, will it engage vtec at the set rpm no matter wat throttle position? thanks guys
Old Sep 9, 2003 | 09:42 AM
Eyewitness's Avatar
Default Re: (Bongnak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bongnak &raquo;</TD></TR><TR><TD CLASS="quote">I a d series person, and know enough about them, but i dont about b series' just yet. I really want to turbo the b block whether it be a ls head or b16 head. if i were to get a b16 head would it be ok to run obd0 and have an external vtech switch? i havent looked into ths yet but the connectors look similar if not the same. the ecu i will use is an extra pr4 i have chipped for ghettodyne. that way i can reburn the fuel map and timming to run proper fuel and timming and wat not.
Get a b16 head for the b16 block....vtec kicks in at the same rpms every time past or full throttle
Old Sep 9, 2003 | 12:14 PM
skribblah's Avatar
Default Re: b20 head on b16 block (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">B16noTEC</TD></TR></TABLE>
HAHAHAHAH!!!!!
Old Sep 10, 2003 | 04:06 AM
Audi RS4's Avatar
Lover
A reversal CRVTEC??? That's like a B16noTEC </TD></TR></TABLE>
thanks for the first morning laugh
mia305sk8a
Sep 20, 2010 05:13 PM
herk_1
Oct 29, 2008 10:35 AM
I LUV MY NINJA
Aug 27, 2006 09:43 PM
b20vtechatch
Acura TL, RL & ZDX
Oct 7, 2004 12:19 PM
Blaze45
Dec 29, 2002 03:34 PM
