wuts the difference of all sensors of 99 si and gsr 96-up ?
wuts the difference btw all sensors of 99 si and gsr 96-up? also wut harness and ecu for ls/vtech se
I want to use a 96 gsr harness for a 99 si engine, but im not sure if the sensors go to togther or not? I just need some info on which sensors are different and and which are the same? also, wut harness and ecu should i use if i did a ls/vtech swap with a b16a2 head and 94- up ls block. This my first time in honda tech so plz help out. thanks
Modified by oo7oo7 at 11:23 AM 9/7/2003
Modified by oo7oo7 at 11:24 AM 9/7/2003
Re: wuts the difference btw all sensors of 99 si and gsr 96-up? also wut harness and ecu for ls/vtec
they dont, you need a 99-00 harness, the ecu plugs are different. convert your stock harness
keogsr1
05-16-2007 11:29 AM
