h22a swap in ek
h22a swap in ek
well frist off im new to this site and i think its great nice pics and info.
im doing a swap in a 96 civic im almost done the only thing i have left is the wiring i was told to use the stock harness of the civic which should be right cause i also bought the obd jumper. i labeled the whole harness before i took it off the dx motor now is it just plug and play or what ? i know i have to wire vtec but there seems like theres still something missing if some one could get back to me with some info.
Re: h22a swap in ek (98jdmdc2)
With a DX, you'll need to add knock sensor (1 wire), vtec (two wires to the ECU, one to the thermostat housing), EGR and IAB. You'll ALSO need to do the IACV fix from the three wire IACV to the two wire IACV plug off the H22.
To make life easier and eliminate all the above, (with exception of IAB and EGR), I'd recommend getting an EX harness. The IACV is already the two wire plug, along with VTEC and Knock already on the harness.
You will, also need to extend wires (mainly alternator), and some other sensors depending on how you place the harness on the motor. But MAP, TPS and all of those will plug right up. It's just the fact of 'reaching' the sensor.
Re: h22a swap in ek (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison »</TD></TR><TR><TD CLASS="quote">With a DX, you'll need to add knock sensor (1 wire), vtec (two wires to the ECU, one to the thermostat housing), EGR and IAB. You'll ALSO need to do the IACV fix from the three wire IACV to the two wire IACV plug off the H22.
right on the money...
LXguy
02-04-2002 07:40 PM
