Which axle to use!?!??!?!
Old Sep 7, 2003 | 09:27 AM
d357r0y's Avatar
Default Which axle to use!?!??!?!
Here is the situation:
91 civic si zc intermediate shaft.. which driver's side axle do I use?
Thanks in advance!
Old Sep 7, 2003 | 09:29 AM
92b16vx's Avatar
Pretty sure you can use the teg D16A8/9's axle, or another dohc D series.
Old Sep 7, 2003 | 01:22 PM
d357r0y's Avatar
Default Re: (92b16vx)
That is what I was thinking also. I just wasn't sure about splines on the hubs / knuckles
Old Sep 8, 2003 | 03:09 PM
92b16vx's Avatar
Default Re: (d357r0y)
From what I know, the splines and diameters are all the same. The HF is the one that is screwed with a smaller diameter.
Old Sep 8, 2003 | 03:14 PM
Katman's Avatar
Default Re: Which axle to use!?!??!?! (d357r0y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">Here is the situation:
Thanks in advance!</TD></TR></TABLE>
Ok, if you have a true DOHC ZC tranny you'll have to use the intermediate shaft it came with or an 89-91 B16A int. shaft. For axles you have to use any 90-93 integra axles. You CANNOT use any D-series axles at all with a DOHC ZC tranny at all, the spline endings are too small (in diameter) to fit into the ZC tranny differential.
Old Sep 13, 2003 | 06:49 AM
d357r0y's Avatar
Default Re: Which axle to use!?!??!?! (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">You CANNOT use any D-series axles at all with a DOHC ZC tranny at all, the spline endings are too small (in diameter) to fit into the ZC tranny differential.</TD></TR></TABLE>
100% true.. I just tried to mate up a zc shaft with a d series axle. Looks like I'll be making a custom axle and having the ZC shaft machined on the tranny end to see if I can make a half shaft.. blah.
honda_coupe
Mar 8, 2009 06:40 AM
prelude182
Jan 9, 2009 12:50 PM
teewhy55
Sep 6, 2005 12:12 AM
ktp1798
Aug 22, 2005 01:42 PM
tdc
Mar 5, 2002 07:23 PM
