95 dx harness, 95 b18b engine
I'm currently using a d16z6 wiring harness on my b18b in my 93 si. I have a resistor pack for 680cc injectors wired into the harness to work with my hondata. I have to run around with the stock injectors and ecu for a while. As you know, I can't just put my stock injectors and ecu back in without removing the resistor box from my harness and rewiring it to stock. Rather than doing this, there is a 95 dx engine harness I have access too. However, I did a search and also remember reading a while back about a dx harness not having the same distributor wires as b series engines? Is there any way I can make a 95 dx harness work on a 95 b18b without cutting some of the distributor plugs off of my d16z6 harness? Thanks.
I've never heard about the distributor wires being different, other than one being a vtce distributor and the other a non, but it seems it should stiil plug in.
wfocrx
07-19-2007 10:22 PM
sytema
08-18-2003 07:06 PM
