need help, i need a TPS sensor for the 1st gen b16a
the tps sensor broke during shipping of my b16, ive been looking online for a few days but came up unlucky in finding a TPS. most ppl want ya to buy a HP throttlebody that comes witht he tps, if this si as good as it gets then i guess ill spend a few extra bucks and put a 68mm throttle body on, but if anyone knows a lil bit cheaper way then lemme know, thanks for your help.
Re: need help, i need a TPS sensor for the 1st gen b16a (alteredego9)
I think I may have one laying around I ll see what I can do. Adjusting the voltage on them sucks unless you make a custom tool for it.
If it has the OEM style rivet bolts, just take a Dremel and notch them, then use a flathead screwdriver to remove them. I'm not sure what the original motor you had that the B16 replaced, but you should be able to reuse the old TPS from it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alteredego9 »</TD></TR><TR><TD CLASS="quote">the tps sensor broke during shipping of my b16, ive been looking online for a few days but came up unlucky in finding a TPS. most ppl want ya to buy a HP throttlebody that comes witht he tps, if this si as good as it gets then i guess ill spend a few extra bucks and put a 68mm throttle body on, but if anyone knows a lil bit cheaper way then lemme know, thanks for your help.
All TPS sensors are then same. So you don't need one specifically from a first gen B16. Sorry, I don't have any extras laying around.
Re: (GSRswapandslow)
Just reuse the TPS off the motor you are taking out of your car. I had to do that with my B16a since it's TPS was also smashed.
Worked like a charm.
86civicsi
10-21-2005 07:41 AM
