ZC dohc Swap in 95hatch
Old 09-04-2003, 03:15 AM
Jmorin's Avatar
Default ZC dohc Swap in 95hatch
Hey Everyone, I was just wondering if it was possible?,I have a hydro clutch and I know the ZC setup has a cable,What would i need to do this swap? and is it just worth going for a h22,The thing is i dont have the loot for a h22 yet but i can get the ZC off a friend whos got it in his Rex.
Please Dont flame cause i a noob
Old 09-04-2003, 04:31 AM
eg6ajk's Avatar
Default Re: ZC dohc Swap in 95hatch (Jmorin)
you are talking about two different spectrums. first few hundred $$$ setup which will run 15's and a more hardcore requiring 'custom' mounts and few tricks; h22a which is priced in $3-4k range and will run 13's.
will a ZC fit yes, but a mount, electronics will need to be used from OBDI car. some ghetto rigging of the distributor (unless you can find OBDI ZC dizzy). all in all worthless swap unless you getting it free or cheap.
as far as h22a much more complicated and requires, from mounts, tranny, ecu, axles, wiring, linkages to some hammer work. excellent swap for those who want a quick car with a potential.
if you want something more cost effective look into a D16z6 or D16y8 along with the tranny and ECU. (if you don't already have one) otherwise, B18B, B20B, B16A will be a little cheaper then H22A and will run 14's without too much help.
civic8594
10-28-2008 11:26 AM
myJDM89EF
09-12-2005 11:05 AM
SkankyEJ7
11-28-2004 10:23 AM
brian estrada
11
04-20-2003 09:21 AM
PsychO
12-12-2002 03:55 PM
Quick Reply: ZC dohc Swap in 95hatch
