need help on a jdm b18b swap into my ek. harness/ecu ??
I got a 97 b18b from japan and its lacking some sensors. I also have a usdm obd2 ls ecu. How should I wire this up? Someone said go with a obd 0 ecu and some other stuff. Can someone tell me the easiest route to making this work? Thanx for any help.
Re: need help on a jdm b18b swap into my ek. harness/ecu ?? (kholmes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kholmes »</TD></TR><TR><TD CLASS="quote">I got a 97 b18b from japan and its lacking some sensors. I also have a usdm obd2 ls ecu. How should I wire this up? Someone said go with a obd 0 ecu and some other stuff.</TD></TR></TABLE>
OBD0? No No No!!! Depending on the year LS ECU you have, you'll need a 96-99 OBD2 LS ECU which will match your ECU plugs. Transfer your stock engine harness onto the B18B and extend wires as needed. You can also use the OBD1 LS ECU with an OBD2 to OBD1 adapter harness. But whoever told you OBD0.....
Re: need help on a jdm b18b swap into my ek. harness/ecu ?? (VTECVillain)
It might have been obd 1 maybe, i cant remember. The thing is i put the d16y7 harness on and Ive got like 4 plugs left over. From what I understood is there isnt a crank sensor or knock sensor but not sure. And the ecu I have is a 98 but didnt think it would work cause it would be looking for those sensors!?
AdrenalineAngel
10-31-2012 09:22 PM
