b20 turbo swap for a 2000 civic si
i want to do a b20 (crv engine) with turbo and swap out the b16a2. my question is what problems will i run into with this swap. what kind of boost is needed to run 12's in the quarter mile. will the tranny off the b16 work with it and will i need to acquire different axles, also where can i get one of these engines.
Re: b20 turbo swap for a 2000 civic si (2000civicsi61)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi61 »</TD></TR><TR><TD CLASS="quote">my question is what problems will i run into with this swap</TD></TR></TABLE>
A lot if you don't do research first, start by using Honda-Tech Search
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi61 »</TD></TR><TR><TD CLASS="quote">what kind of boost is needed to run 12's in the quarter mile.</TD></TR></TABLE>
That depends on a lot of factors but a good ball park would be 9-12 psi
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi61 »</TD></TR><TR><TD CLASS="quote">will the tranny off the b16 work with it and will i need to acquire different axles</TD></TR></TABLE>
Yes it will work, no you won't need new axles. The shorter gearing won't let you stay in boost as long as say and LS tranny would but many people drive turbo'd setups with the Si tranny and have good results.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi61 »</TD></TR><TR><TD CLASS="quote">also where can i get one of these engines.</TD></TR></TABLE>
H Motors Online
Import Auto Salvage
Local Salvage Yards, etc.
H Motors Online
Import Auto Salvage
yudruln2402
11-03-2004 04:20 PM
